Ir para o conteúdo principal
Zoomer Jurassic World Indominus Rex Mouth Gears Replacement
O que você precisa
  1. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement, Mouth Part: passo 1, imagem 1 %32 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement, Mouth Part: passo 1, imagem 2 %32
    • Flip the toy over to gain direct access to the first screws you need to remove for the replacement.
    • Remove the two (2) 7.5mm phillips screws using Phillips #1 screwdriver from the bottom of the jaw.
    • Remove the two (2) 7.2mm phillips screws using Phillips #0 screwdriver from the bottom of the jaw.
    • Gently remove the entire bottom jaw piece.
  2. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: passo 2, imagem 1 %32 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: passo 2, imagem 2 %32 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: passo 2, imagem 3 %32
    • Remove the 7.5mm phillips screw using Phillips #1 screwdriver from the middle of the tongue.
    • Using a spudger, gently pry the tongue out of the mouth.
  3. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement, Mouth Gears: passo 3, imagem 1 %32 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement, Mouth Gears: passo 3, imagem 2 %32 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement, Mouth Gears: passo 3, imagem 3 %32
    • After removing the tongue, inspect and remove any debris from the inside of the mouth.
    • Remove the four (4) 7.5mm phillips screws that are inhibiting your ability to successfully remove the motor inside the mouth.
    • Remove the two (2) 7.2mm phillips screws that fasten the motor to the inside of the mouth.
  4. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: passo 4, imagem 1 %32 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: passo 4, imagem 2 %32 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use a pair of tweezers to remove the motor assembly from the mouth and inspect for any apparent issues.
    • Use a #1 Phillips Screwdriver to remove the two (2) 5.5mm phillips screws to remove the motor from the rest of the assembly.
    • Use tweezers to gently remove the motor from the rest of the assembly.
  5. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: passo 5, imagem 1 %32 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: passo 5, imagem 2 %32 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: passo 5, imagem 3 %32
    • Use tweezers, inspect the main output gear for the jaw and remove if necessary.
    • Remove the four (4) 4.9mm screws from the other side of the assembly.
    • Use a spudger to gently pry apart the assembly for inspection.
  6. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: passo 6, imagem 1 %32
    • Inspect the gears inside the assembly and replace any gears that have flattened or rounded teeth.
Conclusão
Luke Selby
Membro desde: 01/20/16
636 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 10-3, Remmell Spring 2016 Membro de USF Tampa, Team 10-3, Remmell Spring 2016
USFT-REMMELL-S16S10G3
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 705
