Ir para o conteúdo principal
Zoomer Dino Boomer Back Button Replacement
O que você precisa
  1. Zoomer Dino Boomer Back Button Replacement, Back Cover: passo 1, imagem 1 %32
    • Power off Zoomer Dino Boomer before disassembly.
    • Remove the eight 9.3mm Phillips #1 screws.
  2. Zoomer Dino Boomer Back Button Replacement: passo 2, imagem 1 %32 Zoomer Dino Boomer Back Button Replacement: passo 2, imagem 2 %32
    • Turn dinosaur over and hold upright.
    • Use the spudger to pry apart the back cover from the remainder of the Zoomer Dino Boomer.
    • Be gentle while removing the back cover. The back cover of the Zoomer Dino Boomer is still connected to the electronic system by a wire.
  3. Zoomer Dino Boomer Back Button Replacement: passo 3, imagem 1 %32 Zoomer Dino Boomer Back Button Replacement: passo 3, imagem 2 %32 Zoomer Dino Boomer Back Button Replacement: passo 3, imagem 3 %32
    • Disconnect the wire that connects the back cover of the dino to the main circuit board by carefully pulling on the orange wire connector with tweezers.
    • Remove back cover.
    • If you are having difficulty removing the connector from its socket, push in the small tabs on the side of the connector with the tweezers. This step may take some work.
    • Do not damage the wires or circuit board.
  4. Zoomer Dino Boomer Back Button Replacement, Back Button: passo 4, imagem 1 %32
    • Where the button is largest, squeeze the two white tabs together.
  5. Zoomer Dino Boomer Back Button Replacement: passo 5, imagem 1 %32
    • Push in the white circular piece between these tabs as far as it will go.
  6. Zoomer Dino Boomer Back Button Replacement: passo 6, imagem 1 %32 Zoomer Dino Boomer Back Button Replacement: passo 6, imagem 2 %32
    • Where the button is smallest, squeeze the two white tabs together and press the circular tab in-between them until the button comes loose.
    • Remove the back button.
Conclusão
Lauren Mannix
Membro desde: 08/29/15
392 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 16-1, Wollert Fall 2015 Membro de USF Tampa, Team 16-1, Wollert Fall 2015
USFT-WOLLERT-F15S16G1
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 1,959
