Ir para o conteúdo principal
Zoombak Personal GPS Locator Battery Replacement
O que você precisa
  1. Zoombak Personal GPS Locator Battery Replacement, Battery: passo 1, imagem 1 %32
    • Zoombak Personal GPS device
  2. Zoombak Personal GPS Locator Battery Replacement: passo 2, imagem 1 %32
    • Backside has four rubber plugs. Remove them and find the Phillips head screws.
  3. Zoombak Personal GPS Locator Battery Replacement: passo 3, imagem 1 %32
    • Use a small tip flat blade screw driver to remove the rubber plugs.
  4. Zoombak Personal GPS Locator Battery Replacement: passo 4, imagem 1 %32
    • Plugs removed
  5. Zoombak Personal GPS Locator Battery Replacement: passo 5, imagem 1 %32
    • Rubber plugs
  6. Zoombak Personal GPS Locator Battery Replacement: passo 6, imagem 1 %32
    • Remove the bottom cover.
  7. Zoombak Personal GPS Locator Battery Replacement: passo 7, imagem 1 %32
    • Old battery. No numbers just 3.7 volt 890mAh. Very difficult to figure out. I found a Sony Erricson J100, J220, W710, W810, Z300, Z710 battery that fits perfectly.
  8. Zoombak Personal GPS Locator Battery Replacement: passo 8, imagem 1 %32
    • The old one was swollen from being on the charger for so long.
  9. Zoombak Personal GPS Locator Battery Replacement: passo 9, imagem 1 %32
    • The case without the battery.
  10. Zoombak Personal GPS Locator Battery Replacement: passo 10, imagem 1 %32
    • New battery installed.
  11. Zoombak Personal GPS Locator Battery Replacement: passo 11, imagem 1 %32
    • And turn it back on, and it blinks green! I let it run down and recharged the battery. I get about 3 days use from it now. Good luck!
Conclusão
3 outras pessoas executaram este guia.
James
Membro desde: 10/04/10
113 Reputação
Autoria de 1 guia
2 comentários
Excellent guide! Precise step-by-step instructions. The recommended replacement battery was a perfect fit, and works like the original battery. Took about 20 minutes and approx $5.00 for the new battery to do the entire job.
I wish all how-to guides were as well written and easy to follow as this one. Thanks!
j fkmetz - Responder
Zoombak.com is gone. How do I reactivate mine, and get the software that did the tracking back.
Sean Connors - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 4,248
