Introdução
The Zoombak's battery life weakens over time and it needs to be replace. It will no longer hold a charge. Instead of shipping it back to the company and paying to have the battery replaced, you can do it yourself if you have the right tools and the right battery. Finding the right battery was the most challenging part.
I found a Sony Erricson J100, J220, W710, W810, Z300, Z710 battery that fits perfectly.
  1. Zoombak Personal GPS device
    • Zoombak Personal GPS device
  2. Backside has four rubber plugs.  Remove them and find the Phillips head screws.
    • Backside has four rubber plugs. Remove them and find the Phillips head screws.
    • Use a small tip flat blade screw driver to remove the rubber plugs.
    • Plugs removed
    • Rubber plugs
    • Remove the bottom cover.
    • Old battery. No numbers just 3.7 volt 890mAh. Very difficult to figure out. I found a Sony Erricson J100, J220, W710, W810, Z300, Z710 battery that fits perfectly.
    • The old one was swollen from being on the charger for so long.
    • The case without the battery.
    • New battery installed.
    • And turn it back on, and it blinks green! I let it run down and recharged the battery. I get about 3 days use from it now. Good luck!
Conclusão
3 outras pessoas concluíram este guia.
James
113 reputação
Autoria de 1 guia
Excellent guide! Precise step-by-step instructions. The recommended replacement battery was a perfect fit, and works like the original battery. Took about 20 minutes and approx $5.00 for the new battery to do the entire job.
I wish all how-to guides were as well written and easy to follow as this one. Thanks!
j fkmetz - Responder
Zoombak.com is gone. How do I reactivate mine, and get the software that did the tracking back.
Sean Connors - Responder
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Todo: 3,953
