Introdução
If the screen is poorly pixelated, cracked, or blank when turned on, then the screen will need to be replaced. This will require the performance of several steps to remove the casing, as well as the button board, in order to reach the actual component.
O que você precisa
Place device face up and pry off the four knobs using the flat end of the plastic opening tool.
With the bottom of the device on a table, lift the top of the device and gently place it aside.
Does anyone know where to buy replacement parts?
Hi I have questions where can I find sell for zoom H6 ?
Me too. I have contact Zoom but no answer..
Nacho -
Unscrew three (PH #1), 7 mm screws (two on right side of display and one on the bottom left).
Using a plastic opening tool, unlatch the clip and carefully unplug the ribbon connector from the device .
Set the button board aside.
Use a plastic opening tool to lift the screen from the the backing.
Replace the screen.
Good Day,
Where I can purchase this LCD Screen? My LCD display has big black dot at the center of screen.
Please send me how to order the LCD screen and how much possible cost, thanks.
I was provided with a LCD screen with the backing. You then have to unscrew the backing from the buttonboard. I think this makes it easier to reach the latch of the ribbon connector.
When reassembling take care:
1) to correctly place the ribbon connector into the latches
2) verify the buttonboard is correctly reconnected to the mainboard,
3) the menu button as well as the power button on both the sides are well in place and moving correctly,
I needed around 25 min to completely replace the screen.
At the end, do a test run to ensure the device works properly.
10 outras pessoas executaram este guia.
26 comentários
Hello.
I-m so glad to find this tutorial.
I just have one question, do you know where can i get a LCD screen for my zoom H6. I live in France, i’ve been looking for it on the web but nothing. Thankyou for your help.
Hey friend, check bellow.
Hadrien -
Hi, I have the same question, where can I get the display? in the zoom support they do not respond. Thanks
Hi guys, same problem. I just found this, could it be this screen ? http://www.hktdc.com/suppliers-products/...
Hi guys, I found my H6 screen here : https://shop.audiotronic.fr/fr/ The team is very nice and helpful, don’t hesitate to call them.
Thank you for your help!!!
Hi, I have a question ... My Zoom H6 fell to the ground, and besides the display being white the same does not recognize the system in my Macbook or I do not know to access it anywhere. Does it only solve the problem?
this lcd screen isn't available anymore at https://shop.audiotronic.fr/fr/
Any alternatives?
Hello. You did it?
Araujo -
hello anyone found recent parts ? audiotronic seems to be out of stock for h6 screen
Does anyone know where I can get a Zoom H6 screen replacement part in Australia?
if you have any luck, let me know, also looking… thanks mate
Hello! me too have been searching for this screen-replacement and i’ve found the source. the problem is that i have to order many of them to buy them at all.
if there is is enough interest maybe we could order them together?
i’m interested… in at least one, maybe two
Amazing feedback, but never been able to get the darn part… tried both options, audiotronic, and hktdc, no luck … anyone else have any luck ? thanks guys
Hélio guys ! I’m from Brazil and I’d like to buy a LCD DISPLAY FOR ZOOM H6. We don’t have ano places here with these component. Anybody here can help me ?
I am looking or it, too! I haven't find it anywhere.
Caras, boa noite. Vocês conseguiram resolver? Abs
Eu estou louco em busca desta tela LCD… Quem encontrar avisa!
piitela -
Dear sir
I am Madan from India. can i get the Zoom h6 display ribbon. Pl. inform me. my mail id is pragnyacreations@gmail.com
Any updates on where to purchase a screen replacement?
Eu moro no Brasil. Estou com o mesmo problema a mais de 1 ano. Entrei em contato com varias autorizadas/fornecedores e eles falam que estão sem estoque, depois entrei em contato inclusive com a própria ZOOM, mas sem retorno. Onde eu consigo comprar o display LCD, para finalmente resolver a minha situação?
English:
I live in Brazil. I've had the same problem for over 1 year. I contacted authorized vendors and they say they are out of stock so I even contacted ZOOM itself twisted but no. Where can I buy the LCD display, to finally solve my situation?
Wow, great. No solution to this problem, apparently. Why does Zoom have this good reputation? Apparently, they send you a new unit for about ⅔ of the price of a new one if you send yours in. Despicable.
