Introdução
The requirements for this guide are the right tools and the device itself. The motherboard should be removed when trying to access the internal components of the recorder.
O que você precisa
Place device face up and pry off the four knobs using the flat end of the plastic opening tool.
With the bottom of the device on a table, lift the top of the device and gently place it aside.
Does anyone know where to buy replacement parts?
Hi I have questions where can I find sell for zoom H6 ?
Me too. I have contact Zoom but no answer..
Nacho -
Unscrew three (PH #1), 7mm screws from the display backing and gently flip over.
Olá como faço para comprar o display para esse gravador
Queimou o display do meu gravador h-6 vocês podem me ajudar
Gently remove three ribbon connectors from the device.
The first is connected to the mic connector.
The second is connected to the base of the device, and the third is connected to the power switch on the side of the device; turn the device 180 degrees, and the connectors are near the top of the device next to the "LINE OUT" plug-in (directly behind the device display).
5 outras pessoas executaram este guia.
13 comentários
Good night Mr.
I have a H6 recorder H.6 handy recorder, never use, but the battery stay in and it leak in the box.
When i remove the leaking battery, and i renew the battery the recorder did not start. According a technician the aparatus have to be open and chance the plate, but we does not have those technician on the island. please advice.
Edgar.
hello, i just have a question, where can i find this parts?
Can i get Zoom H6 Handy Recorder Motherboard only i need it and the price
Yes here ! https://shop.audiotronic.fr/en/61-h6
What was the problem? How do you diagnose a bad LCD screen? My screen goes white and nothing else comes on. So there is power, but nothing comes on the screen but the white background.
I have the same issue with my H6. Do let me know the salutations if you got any... Thanks 🙏
peeaks.com@gmail.com
For me, the recorder turns on, the screen is white and nothing else. Please tell me how to solve this problem. smincs@hotmail.com
The motherboard is no longer available on the above site https://shop.audiotronic.fr/en/61-h6
Any ideas on where to find it?
Hi, we have Zoom H6 recorder, mother needs replacement, can someone help in India. If there are any authorized centers for repairs in India, please guide. Thanks
Congratulations for H6 !
What about Zoom F4 Recorder?!
You have any solutions for this device?!
How can I get the motherboard replacement for zoom H6n and how much will it cost me? +2348033706620 Whatsapp
