Introdução
The requirements for this guide are the right tools and the device itself. The casing should be removed when trying to access the internal components of the recorder.
O que você precisa
Place device face up and pry off the four knobs using the flat end of the plastic opening tool.
With the bottom of the device on a table, lift the top of the device and gently place it aside.
Does anyone know where to buy replacement parts?
Hi I have questions where can I find sell for zoom H6 ?
Me too. I have contact Zoom but no answer..
Nacho -
4 outras pessoas executaram este guia.
7 comentários
Where can I get the replacement part. I need to change the casing of my h6 and the power button
Did you get to find the replacement casing? Where did you find it?
I need a case replacement, too. There is so much broken, hardly to fix with glue …
anything?
contact your nearest dealer listed on the zoom website to buy a replacement set. They shipped me one after the cover finish turned ‘sticky’ and the battery plate lock mechanism broke off due to the plastic going bad. this can happen i.e. after you leave it the sun for too long, which happened to me. this tutorial doesn’t cover the bottom case which is more involving with all the electronics.
Hi, who, or where, is the dealer that gets you the spare case? Im looking for that for a year, thank you.
Saludos
¿Dónde podría comprar la carcasa para cambiarla por la original?
Gracias
