Ir para o conteúdo principal
Zoom H1 Handy Recorder Speaker Replacement
O que você precisa
  1. Zoom H1 Handy Recorder Speaker Replacement, Speaker: passo 1, imagem 1 %32
    • Turn the device over with its display down.
  2. Zoom H1 Handy Recorder Speaker Replacement: passo 2, imagem 1 %32
    • Remove the battery cover, pressing down on the tabs and sliding.
  3. Zoom H1 Handy Recorder Speaker Replacement: passo 3, imagem 1 %32
    • Unscrew the two (2) #00, 10 mm screws located below the mic on the back cover.
  4. Zoom H1 Handy Recorder Speaker Replacement: passo 4, imagem 1 %32
    • Carefully pry up the top end of the back cover using one finger.
  5. Zoom H1 Handy Recorder Speaker Replacement: passo 5, imagem 1 %32
    • Remove the back plate by using a plastic removal tool to pry the back cover up around the edges.
  6. Zoom H1 Handy Recorder Speaker Replacement: passo 6, imagem 1 %32
    • De-solder the white and black speaker wires from their soldering points.
    • Speaker soldering points are located on the thin section of the blue circuit board, and are marked with “SP+” and “SP-”.
    • Keep in mind which color wire was connected at which terminal.
  7. Zoom H1 Handy Recorder Speaker Replacement: passo 7, imagem 1 %32
    • Remove the damaged speaker from its place at the very bottom of the case, just below the battery input.
    • You will have to break the glue holding the speaker in place before removing it.
  8. Zoom H1 Handy Recorder Speaker Replacement: passo 8, imagem 1 %32
    • Replace the damaged speaker and re-solder to the original solder points.
    • Ensure that the negative wire is soldered to the “SP-” while the positive wire is soldered to the “SP+” point.
Conclusão
Alex
Membro desde: 10/28/13
809 Reputação
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 7
Ao todo: 1,873
