Ir para o conteúdo principal
Zipper Stop Replacement
O que você precisa
  1. Zipper Stop Replacement, Stop: passo 1, imagem 1 %32
    • Evaluate the damage and examine the zipper for any indications of fracture, misalignment, or looseness.
  2. Zipper Stop Replacement: passo 2, imagem 1 %32
    • Align the zipper stop so the post is on the same side as the zipper slider.
  3. Zipper Stop Replacement: passo 3, imagem 1 %32
    • Gently place the stop beneath the zipper teeth.
  4. Zipper Stop Replacement: passo 4, imagem 1 %32 Zipper Stop Replacement: passo 4, imagem 2 %32
    • After the stop has been positioned appropriately, clamp it in place with the needle nose pliers.
    • To ensure a snug fit, use firm pressure at multiple points to clamp the stop tightly around the zipper teeth.
  5. Zipper Stop Replacement: passo 5, imagem 1 %32
    • To make sure the stop is firmly attached to the zipper track, gently tug on it after clamping it. Reclamp the stop if needed.
Linha de Chegada
Dejia P.
Membro desde: 02/20/24
121 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 20
Últimos 30 dias: 147
Ao todo: 1,288
