Introdução
This is a guide for replacing the motherboard of your Zeki device.
First, to reach the motherboard, remove the plastic backing, then the battery, and lastly the camera.
After replacing the motherboard, the device will need to be reassembled in the opposite order.
O que você precisa
Remove the two screws from the end of the device where the ports are located using a Phillips #1 screwdriver.
