Ir para o conteúdo principal
Zeki TBQG884B Camera Replacement
O que você precisa
  1. Zeki TBQG884B Camera Replacement, Rear Case: passo 1, imagem 1 %32 Zeki TBQG884B Camera Replacement, Rear Case: passo 1, imagem 2 %32
    • Remove the two screws from the end of the device where the ports are located using a Phillips #1 screwdriver.
  2. Zeki TBQG884B Camera Replacement: passo 2, imagem 1 %32
    • Place the tablet down so that the screen is facing away from you.
    • Insert the tip of your opening tool into the small gap between the gray and white plastic covering. Pry it open and you should hear the clips opening up.
    • Gently work your way around the perimeter of the tablet's edge.
  3. Zeki TBQG884B Camera Replacement: passo 3, imagem 1 %32 Zeki TBQG884B Camera Replacement: passo 3, imagem 2 %32
    • Remove the back cover
    • Remove any tape on the speaker and detach the speaker from the back plate.
    • The speaker is connected to the motherboard by two soldered wires. Don't break them when you remove the speaker.
  4. Zeki TBQG884B Camera Replacement, Camera: passo 4, imagem 1 %32 Zeki TBQG884B Camera Replacement, Camera: passo 4, imagem 2 %32
    • Open the ZIF connector, the black lock part over the wire ribbon in the motherboard, and remove the wire ribbon that connects the motherboard and the camera.
    • The camera is located on the top left, above the motherboard.
    • The camera is usually covered with tape or material. Peel material/tape off with tweezers for safety.
Conclusão
Natalie Holm
Membro desde: 09/16/15
137 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 1-3, Harley Fall 2015 Membro de IUPUI, Team 1-3, Harley Fall 2015
IUPUI-HARLEY-F15S1G3
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 266
