Introdução
This step-by-step guide will help you replace a damaged camera on a Zeki TBQG884B tablet.
A proper functioning camera is essential for capturing photos, scanning documents and engaging in video calls. If the camera is faulty or damaged, replacing it will help restore these functionalities.
O que você precisa
Remove the two screws from the end of the device where the ports are located using a Phillips #1 screwdriver.
Open the ZIF connector, the black lock part over the wire ribbon in the motherboard, and remove the wire ribbon that connects the motherboard and the camera.
