Ir para o conteúdo principal
Zeki Droid Tablet Front Screen Replacement
O que você precisa
  1. Zeki Droid Tablet Front Screen Replacement, Back Casing: passo 1, imagem 1 %32
    • Remove the back casing by slowly popping each tab out with a plastic opening tool.
  2. Zeki Droid Tablet Front Screen Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the tapes one by one from the connecting wires with tweezers.
  3. Zeki Droid Tablet Front Screen Replacement: passo 3, imagem 1 %32
    • Remove the black clips from both sides of the casing with a plastic opening tool.
    • The clips should pop off separate from the speakers.
  4. Zeki Droid Tablet Front Screen Replacement: passo 4, imagem 1 %32
    • Remove the speakers from the back casing.
    • Do not tug on the speakers because they are connected to fragile wires.
  5. Zeki Droid Tablet Front Screen Replacement: passo 5, imagem 1 %32
    • Pull the speakers away from the back casing carefullly.
  6. Zeki Droid Tablet Front Screen Replacement, Front Screen: passo 6, imagem 1 %32
    • Detach the motherboard from the framing by removing the four screws using a Phillips #000 screwdriver.
  7. Zeki Droid Tablet Front Screen Replacement: passo 7, imagem 1 %32
    Comprar
    • Lift the camera and flash components from their fittings using tweezers.
  8. Zeki Droid Tablet Front Screen Replacement: passo 8, imagem 1 %32
    • Lift the metal framing to reach the components at the front of the device.
    • Do not pull the framing completely off. There is a ZIF connecter holding it in place.
  9. Zeki Droid Tablet Front Screen Replacement: passo 9, imagem 1 %32 Zeki Droid Tablet Front Screen Replacement: passo 9, imagem 2 %32
    • Push the screen forward to remove.
Conclusão
Kyla
Membro desde: 03/11/15
156 Reputação
Autoria de 2 guias
Equipe
Colorado Springs, Team 2-6, Panko Spring 2015 Membro de Colorado Springs, Team 2-6, Panko Spring 2015
UCCS-PANKO-S15S2G6
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 13
Duração total: 308
