Ir para o conteúdo principal
Zeki Droid Tablet Back Casing Replacement
O que você precisa
  1. Zeki Droid Tablet Back Casing Replacement, Back Casing: passo 1, imagem 1 %32
    • Remove the back casing by slowly popping each tab out with a plastic opening tool.
  2. Zeki Droid Tablet Back Casing Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the tapes one by one from the connecting wires with tweezers.
  3. Zeki Droid Tablet Back Casing Replacement: passo 3, imagem 1 %32
    • Remove the black clips from both sides of the casing with a plastic opening tool.
    • The clips should pop off separate from the speakers.
  4. Zeki Droid Tablet Back Casing Replacement: passo 4, imagem 1 %32
    • Remove the speakers from the back casing.
    • Do not tug on the speakers because they are connected to fragile wires.
  5. Zeki Droid Tablet Back Casing Replacement: passo 5, imagem 1 %32
    • Pull the speakers away from the back casing carefullly.
Conclusão
Wyatt Nelson
Membro desde: 03/11/15
120 Reputação
Autoria de 1 guia
Equipe
Colorado Springs, Team 2-6, Panko Spring 2015 Membro de Colorado Springs, Team 2-6, Panko Spring 2015
UCCS-PANKO-S15S2G6
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 633
