Ir para o conteúdo principal
Zeepad 7DRK Speaker Replacement
O que você precisa
  1. Zeepad 7DRK Speaker Replacement, Speaker: passo 1, imagem 1 %32 Zeepad 7DRK Speaker Replacement, Speaker: passo 1, imagem 2 %32
    • Begin by popping off the plastic yellow device casing with the soft tip prying tool.
    • Start by using the wedging the tip of the tool in and working your way around the device to make things easier.
  2. Zeepad 7DRK Speaker Replacement: passo 2, imagem 1 %32 Zeepad 7DRK Speaker Replacement: passo 2, imagem 2 %32
    • Once the device is opened, the speaker should fall out of its position.
    • Follow the red and black wires attached to the speaker to find the location of connection.
  3. Zeepad 7DRK Speaker Replacement: passo 3, imagem 1 %32
    • The red and black wires are attached by a solder, in order to be replaced this connection must be broken.
    • Once the wires are disconnected, the speaker will be successfully removed and ready for replacement.
Conclusão
Alexandra Souza
Membro desde: 10/20/16
222 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 6-8, Martin Fall 2016 Membro de UMass Dartmouth, Team 6-8, Martin Fall 2016
UMASSD-MARTIN-F16S6G8
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 93
