Ir para o conteúdo principal
Zeepad 7DRK Power and Volume Button Replacement
O que você precisa
  1. Zeepad 7DRK Power and Volume Button  Replacement, Power and Volume Buttons: passo 1, imagem 1 %32
    • First find the power and volume buttons so that you are familiar with their location.
    • The smaller button is the power button and the larger button is the volume button.
  2. Zeepad 7DRK Power and Volume Button  Replacement: passo 2, imagem 1 %32 Zeepad 7DRK Power and Volume Button  Replacement: passo 2, imagem 2 %32
    • To open the tablet, use one of the soft-tip prying tools.
    • It is easiest to start by using the corner of the tool first and sliding the rest in. Then carefully move the tool around the edges of the tablet until it separates.
  3. Zeepad 7DRK Power and Volume Button  Replacement: passo 3, imagem 1 %32
    • Be careful of how you open the tablet, as the button will want to fall out. Try opening it flat on its back to avoid this problem.
    • This is what the tablet looks like when pried apart.
  4. Zeepad 7DRK Power and Volume Button  Replacement: passo 4, imagem 1 %32 Zeepad 7DRK Power and Volume Button  Replacement: passo 4, imagem 2 %32
    • In the first picture you will see the power button. Notice the small plastic ring that sticks out the side, this is so the piece can be positioned easily when you put it back together.
    • In the second picture, the volume control button is shown. Again notice the small locator rings.
  5. Zeepad 7DRK Power and Volume Button  Replacement: passo 5, imagem 1 %32 Zeepad 7DRK Power and Volume Button  Replacement: passo 5, imagem 2 %32
    • Now remove the old or broken buttons, and replace them.
Conclusão
Uma outra pessoa concluiu este guia.
Trevor Taylor
Membro desde: 10/20/16
234 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 6-8, Martin Fall 2016 Membro de UMass Dartmouth, Team 6-8, Martin Fall 2016
UMASSD-MARTIN-F16S6G8
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 359
