Introdução
Use the guide to safely replace the peel and present system with the help of a phillips head screwdriver set.
O que você precisa
Orient the printer so that the bottom is facing up.
Remove the three P1 9mm screws located on the bottom of the printer and remove the lower unit.
Quase terminado!
Conclusão
