Introdução
Has your entire world gone dark? No? Well, has the viewfinder inside your Zeal Optics iON goggles gone dark? If so, use this guide to replace the backlight.
O que você precisa
Hold the iON in your hands with your thumbs on the clips next to the middle of the lens.
Pull the rubber housing apart to release the first two clips.
Remove the four 7.1 mm Phillips screws securing the camera housing to the goggle frame.
Remove the two 7.5 mm Phillips screws on the front of the viewfinder housing.
Remove the four 7.1 mm Phillips screws from the back of the viewfinder housing.
Use your thumbs to lift the tabs holding the viewfinder lens to the LCD assembly.
Pull the viewfinder lens off of the viewfinder LCD.
Use your thumb to push the LCD bracket tab away from the LCD.
Remove the LCD bracket from the LCD and backlight.
