Ir para o conteúdo principal
ZTE ZMAX Z970 Screen Replacement
O que você precisa
  1. ZTE ZMAX Z970 Screen Replacement, Battery: passo 1, imagem 1 %32 ZTE ZMAX Z970 Screen Replacement, Battery: passo 1, imagem 2 %32
    • Insert a fine point tool into the hole on the top left side of the phone to remove the SIM and SD card trays.
    • Pull out the trays.
  2. ZTE ZMAX Z970 Screen Replacement: passo 2, imagem 1 %32 ZTE ZMAX Z970 Screen Replacement: passo 2, imagem 2 %32
    • Insert a plastic opening tool into the groove between the phone’s back cover and casing.
    • Move the plastic opening tool along the edges of the phone to unclip the two pieces.
  3. ZTE ZMAX Z970 Screen Replacement: passo 3, imagem 1 %32 ZTE ZMAX Z970 Screen Replacement: passo 3, imagem 2 %32 ZTE ZMAX Z970 Screen Replacement: passo 3, imagem 3 %32
    • Remove the ten 1.2mm screws with a Phillips #000 screwdriver.
  4. ZTE ZMAX Z970 Screen Replacement: passo 4, imagem 1 %32 ZTE ZMAX Z970 Screen Replacement: passo 4, imagem 2 %32
    • Remove the mid frame with the plastic opening tool.
  5. ZTE ZMAX Z970 Screen Replacement: passo 5, imagem 1 %32 ZTE ZMAX Z970 Screen Replacement: passo 5, imagem 2 %32
    • Disconnect the battery from the motherboard.
  6. ZTE ZMAX Z970 Screen Replacement: passo 6, imagem 1 %32 ZTE ZMAX Z970 Screen Replacement: passo 6, imagem 2 %32
    • Wedge a spudger underneath the battery and gently pry upwards to remove the battery.
    • Once free from the glue, remove from device.
    • The glue holding down the battery is strong so work slow and cautiously to avoid starting a fire.
  7. ZTE ZMAX Z970 Screen Replacement, Screen: passo 7, imagem 1 %32
    • Heat up the iOpener for 30 seconds and place on top of the phone for 2 minutes.
  8. ZTE ZMAX Z970 Screen Replacement: passo 8, imagem 1 %32
    • Wedge the opening picks into all the corners of the phone and lift until the screen comes off.
Conclusão
Ismail Jhaveri
Membro desde: 02/15/18
159 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S17-G3, Boczar Spring 2018 Membro de USF Tampa, Team S17-G3, Boczar Spring 2018
USFT-BOCZAR-S18S17G3
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 1,210
