Ir para o conteúdo principal
ZTE ZFive G LTE Volume and Power Button Replacement
O que você precisa
  1. ZTE ZFive G LTE Volume and Power Button Replacement, Volume and power button: passo 1, imagem 1 %32 ZTE ZFive G LTE Volume and Power Button Replacement, Volume and power button: passo 1, imagem 2 %32 ZTE ZFive G LTE Volume and Power Button Replacement, Volume and power button: passo 1, imagem 3 %32
    • Remove back cover of the device from the crease of the bottom left corner using opening tool or fingernail.
  2. ZTE ZFive G LTE Volume and Power Button Replacement: passo 2, imagem 1 %32 ZTE ZFive G LTE Volume and Power Button Replacement: passo 2, imagem 2 %32
    • Remove the battery with an opening tool or fingernail.
  3. ZTE ZFive G LTE Volume and Power Button Replacement: passo 3, imagem 1 %32 ZTE ZFive G LTE Volume and Power Button Replacement: passo 3, imagem 2 %32
    • Unscrew all 16 screws from the mid-frame with a J000 screwdriver.
  4. ZTE ZFive G LTE Volume and Power Button Replacement: passo 4, imagem 1 %32 ZTE ZFive G LTE Volume and Power Button Replacement: passo 4, imagem 2 %32
    • Being careful with the device, gently pull up the device body tugging from the inside of the device.
    • Be sure to pull away from the device.
  5. ZTE ZFive G LTE Volume and Power Button Replacement: passo 5, imagem 1 %32 ZTE ZFive G LTE Volume and Power Button Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Carefully use a pair of bent nose tweezers to pull out the button cover. I should come out easily.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 319
