Introdução
Use this guide to replace the battery on a ZTE ZFive LTE Android cellphone. Cellphones require the use of a battery to help the cellphone charge and function. When the cellphone starts to overheat or not charge properly it is time to replace it with a new one.
Note that you have to find and purchase the correct battery before starting. With this guide, you will walk through the necessary techniques to accurately replace the battery while helping to prevent potential damage to interior cellphone.
O que você precisa
Using the opening tool, pry open the rear cover from the crease at the bottom left corner.
