Ir para o conteúdo principal
ZTE Tempo X Charging/Aux Board Replacement
O que você precisa
  1. ZTE Tempo X Charging/Aux Board Replacement, Back Cover: passo 1, imagem 1 %32 ZTE Tempo X Charging/Aux Board Replacement, Back Cover: passo 1, imagem 2 %32
    • Remove back cover using the divot provided.
  2. ZTE Tempo X Charging/Aux Board Replacement, Battery: passo 2, imagem 1 %32 ZTE Tempo X Charging/Aux Board Replacement, Battery: passo 2, imagem 2 %32
    • Find the divot near the bottom of the battery and remove the battery from the device.
  3. ZTE Tempo X Charging/Aux Board Replacement, Charging/Aux Board: passo 3, imagem 1 %32 ZTE Tempo X Charging/Aux Board Replacement, Charging/Aux Board: passo 3, imagem 2 %32
    • Remove the sixteen 3mm screws using the Phillips #000 screwdriver.
  4. ZTE Tempo X Charging/Aux Board Replacement: passo 4, imagem 1 %32 ZTE Tempo X Charging/Aux Board Replacement: passo 4, imagem 2 %32
    • Take off the second back cover, lifting from the bottom of the device to the top.
  5. ZTE Tempo X Charging/Aux Board Replacement: passo 5, imagem 1 %32 ZTE Tempo X Charging/Aux Board Replacement: passo 5, imagem 2 %32 ZTE Tempo X Charging/Aux Board Replacement: passo 5, imagem 3 %32
    • Using a spudger, unclip the board from the phone at the places highlighted.
  6. ZTE Tempo X Charging/Aux Board Replacement: passo 6, imagem 1 %32 ZTE Tempo X Charging/Aux Board Replacement: passo 6, imagem 2 %32 ZTE Tempo X Charging/Aux Board Replacement: passo 6, imagem 3 %32
    • Use the spudger to remove the board from the phone.
    • The board is held by glue so there will be resistance when detaching it from the phone.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 221
