Ir para o conteúdo principal
ZTE Tempo Front Screen Assembly Replacement
O que você precisa
  1. ZTE Tempo Front Screen Assembly Replacement, Battery: passo 1, imagem 1 %32 ZTE Tempo Front Screen Assembly Replacement, Battery: passo 1, imagem 2 %32
    • Use a plastic opening tool to pry open the back case.
    • Use a Phillips #0 screwdriver to remove the eight 5mm screws.
    • Use a plastic opening tool to remove the midframe.
  2. ZTE Tempo Front Screen Assembly Replacement: passo 2, imagem 1 %32 ZTE Tempo Front Screen Assembly Replacement: passo 2, imagem 2 %32 ZTE Tempo Front Screen Assembly Replacement: passo 2, imagem 3 %32
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable.
    • Lift the battery up and remove it from the phone.
  3. ZTE Tempo Front Screen Assembly Replacement, Front Screen Assembly: passo 3, imagem 1 %32 ZTE Tempo Front Screen Assembly Replacement, Front Screen Assembly: passo 3, imagem 2 %32 ZTE Tempo Front Screen Assembly Replacement, Front Screen Assembly: passo 3, imagem 3 %32
    • Use the plastic opening tool to unplug the three connectors.
  4. ZTE Tempo Front Screen Assembly Replacement: passo 4, imagem 1 %32
    • Use the plastic opening tool to push up on the wire to remove it completely.
  5. ZTE Tempo Front Screen Assembly Replacement: passo 5, imagem 1 %32 ZTE Tempo Front Screen Assembly Replacement: passo 5, imagem 2 %32
    • Insert and slide the plastic opening tool alongside the seam, gently wiggling the opening tool to open and remove the motherboard.
  6. ZTE Tempo Front Screen Assembly Replacement: passo 6, imagem 1 %32 ZTE Tempo Front Screen Assembly Replacement: passo 6, imagem 2 %32 ZTE Tempo Front Screen Assembly Replacement: passo 6, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use the metal spudger to push up to remove the volume control.
    • Use the tweezers to remove the front speaker and bottom controller.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 307
