Ir para o conteúdo principal
ZTE Tempo Front Camera Replacement
O que você precisa
  1. ZTE Tempo Front Camera Replacement, Front Camera: passo 1, imagem 1 %32 ZTE Tempo Front Camera Replacement, Front Camera: passo 1, imagem 2 %32 ZTE Tempo Front Camera Replacement, Front Camera: passo 1, imagem 3 %32
    • Pry open the back case to get to the back cover.
    • Remove eight 5mm screws with a PH0 screw.
    • Pry open the back cover with a plastic opening tool.
    • Slide the plastic opening tool alongside the side seam twisting your hand forcefully to open the back cover.
    • Note: Pry open by finding an edge and forcing it open with the plastic opening tool.
  2. ZTE Tempo Front Camera Replacement: passo 2, imagem 1 %32 ZTE Tempo Front Camera Replacement: passo 2, imagem 2 %32 ZTE Tempo Front Camera Replacement: passo 2, imagem 3 %32
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable.
    • Lift the battery up and remove it from the phone.
  3. ZTE Tempo Front Camera Replacement: passo 3, imagem 1 %32 ZTE Tempo Front Camera Replacement: passo 3, imagem 2 %32
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the front camera ribbon cable.
    • Lift the front camera out of the phone.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 126
