Ir para o conteúdo principal
ZTE Speed Motherboard Replacement
O que você precisa
  1. ZTE Speed Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 ZTE Speed Motherboard Replacement, Motherboard: passo 1, imagem 2 %32
    • Pull off back cover at bottom right corner.
  2. ZTE Speed Motherboard Replacement: passo 2, imagem 1 %32 ZTE Speed Motherboard Replacement: passo 2, imagem 2 %32
    • Remove the seven 3.175mm Phillips head screws from the inner back located at the top, upper-middle-right, middle-right, lower-right, and bottom.
  3. ZTE Speed Motherboard Replacement: passo 3, imagem 1 %32 ZTE Speed Motherboard Replacement: passo 3, imagem 2 %32
    • With the plastic opening tool the spudger, gently pry off the inner back.
    • Be careful not to pry it off too hard, as it is just a plastic covering.
  4. ZTE Speed Motherboard Replacement: passo 4, imagem 1 %32
    • Remove the one 2.381mm Phillips head screw from the motherboard located in the upper-middle part of the phone next to the bottom left corner of the back camera.
  5. ZTE Speed Motherboard Replacement: passo 5, imagem 1 %32 ZTE Speed Motherboard Replacement: passo 5, imagem 2 %32 ZTE Speed Motherboard Replacement: passo 5, imagem 3 %32
    • Using the spudger, gently pry up all ZIF connectors
    • ZIF connectors have a tiny tab that needs to be flipped up in order to safely remove the cable
    • Using same spudger, gently pry up the orange flat top connector
  6. ZTE Speed Motherboard Replacement: passo 6, imagem 1 %32 ZTE Speed Motherboard Replacement: passo 6, imagem 2 %32
    • Carefully take off motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Garrett Barry
Membro desde: 03/04/16
722 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 6-3, Bhusal Spring 2016 Membro de UMass Dartmouth, Team 6-3, Bhusal Spring 2016
UMASSD-BHUSAL-S16S6G3
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 694
