Ir para o conteúdo principal
ZTE Speed Front and Back Camera Replacement
O que você precisa
  1. ZTE Speed Front and Back Camera Replacement, Front and Back Camera: passo 1, imagem 1 %32 ZTE Speed Front and Back Camera Replacement, Front and Back Camera: passo 1, imagem 2 %32
    • Pull off back cover at bottom right corner.
  2. ZTE Speed Front and Back Camera Replacement: passo 2, imagem 1 %32 ZTE Speed Front and Back Camera Replacement: passo 2, imagem 2 %32
    • Remove the seven 3.175mm Phillips head screws from the inner back located at the top, upper-middle-right, middle-right, lower-right, and bottom.
  3. ZTE Speed Front and Back Camera Replacement: passo 3, imagem 1 %32 ZTE Speed Front and Back Camera Replacement: passo 3, imagem 2 %32
    • With the plastic opening tool the spudger, gently pry off the inner back seal around the phone.
    • Be careful not to pry it off too harsh, as it is just plastic.
  4. ZTE Speed Front and Back Camera Replacement: passo 4, imagem 1 %32 ZTE Speed Front and Back Camera Replacement: passo 4, imagem 2 %32
    • With the spudger, gently pry off camera at the top-middle of the phone to get back camera.
    • With the spudger, gently pry off camera at the top-left of the phone to get the front camera.
Conclusão
3 outras pessoas executaram este guia.
Garrett Barry
Membro desde: 03/04/16
722 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 6-3, Bhusal Spring 2016 Membro de UMass Dartmouth, Team 6-3, Bhusal Spring 2016
UMASSD-BHUSAL-S16S6G3
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 310
