Ir para o conteúdo principal
ZTE Quest n817 Motherboard Replacement
O que você precisa
  1. ZTE Quest n817 Motherboard Replacement, Battery: passo 1, imagem 1 %32 ZTE Quest n817 Motherboard Replacement, Battery: passo 1, imagem 2 %32 ZTE Quest n817 Motherboard Replacement, Battery: passo 1, imagem 3 %32
    • Ensure that the phone is turned off before starting.
    • Orient the device so that the inset on the right side of the device is facing you.
    • Insert the spudger into the inset and carefully remove the back panel.
  2. ZTE Quest n817 Motherboard Replacement: passo 2, imagem 1 %32 ZTE Quest n817 Motherboard Replacement: passo 2, imagem 2 %32
    • Use the ribbon to remove the exposed battery.
  3. ZTE Quest n817 Motherboard Replacement, Motherboard: passo 3, imagem 1 %32
    • Use the JIS #000 screwdriver to remove the six 3.0mm screws placed in the back of the ZTE Quest.
  4. ZTE Quest n817 Motherboard Replacement: passo 4, imagem 1 %32
    • Carefully pry open the back panel with the plastic opening tool.
  5. ZTE Quest n817 Motherboard Replacement: passo 5, imagem 1 %32
    • Use a pair of tweezers to gently disconnect the ribbon cable connector from its socket.
  6. ZTE Quest n817 Motherboard Replacement: passo 6, imagem 1 %32
    • Pull back the tape encasing the brown ribbon cable connector.
    • Remove the ribbon cable from its socket.
  7. ZTE Quest n817 Motherboard Replacement: passo 7, imagem 1 %32
    • Unplug the flat-top connector by using a pair of tweezers to pry up each side before removing the connector from its socket.
  8. ZTE Quest n817 Motherboard Replacement: passo 8, imagem 1 %32 ZTE Quest n817 Motherboard Replacement: passo 8, imagem 2 %32
    • Disconnect the coaxial connector in the bottom right corner of the motherboard.
Conclusão
Eric Loureiro
Membro desde: 10/26/18
582 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team S3-G6, Peak Fall 2018 Membro de UMass Dartmouth, Team S3-G6, Peak Fall 2018
UMASSD-PEAK-F18S3G6
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 476
