Introdução
If you do need to replace your ZTE Quest's motherboard, this guide will take you through the process of opening your device and fully removing the motherboard.
O que você precisa
Orient the device so that the inset on the right side of the device is facing you.
Insert the spudger into the inset and carefully remove the back panel.
Use the JIS #000 screwdriver to remove the six 3.0mm screws placed in the back of the ZTE Quest.
Quase terminado!
Conclusão
