Ir para o conteúdo principal
ZTE Quest n817 Daughterboard Replacement
O que você precisa
  1. ZTE Quest n817 Daughterboard Replacement, Battery: passo 1, imagem 1 %32 ZTE Quest n817 Daughterboard Replacement, Battery: passo 1, imagem 2 %32 ZTE Quest n817 Daughterboard Replacement, Battery: passo 1, imagem 3 %32
    • Ensure that the phone is turned off before starting.
    • Orient the device so that the inset on the right side of the device is facing you.
    • Insert the spudger into the inset and carefully remove the back panel.
  2. ZTE Quest n817 Daughterboard Replacement: passo 2, imagem 1 %32 ZTE Quest n817 Daughterboard Replacement: passo 2, imagem 2 %32
    • Use the ribbon to remove the exposed battery.
  3. ZTE Quest n817 Daughterboard Replacement, Daughterboard: passo 3, imagem 1 %32
    • Carefully pry open the back panel with the plastic opening tool.
  4. ZTE Quest n817 Daughterboard Replacement: passo 4, imagem 1 %32
    • Unplug the flat-top connector by lifting each side of the connector up before fully removing it from its socket.
  5. ZTE Quest n817 Daughterboard Replacement: passo 5, imagem 1 %32
    • Remove the two 2.0mm screws on either side of the daughterboard.
  6. ZTE Quest n817 Daughterboard Replacement: passo 6, imagem 1 %32
    • Remove the coaxial connector that links the daughterboard to the motherboard.
Conclusão
Eric Loureiro
Membro desde: 10/26/18
582 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team S3-G6, Peak Fall 2018 Membro de UMass Dartmouth, Team S3-G6, Peak Fall 2018
UMASSD-PEAK-F18S3G6
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 237
