Ir para o conteúdo principal
ZTE Maven Battery Replacement
O que você precisa
    • Remove the back cover.
  1. ZTE Maven Battery Replacement: passo 2, imagem 1 %32 ZTE Maven Battery Replacement: passo 2, imagem 2 %32
    • If inserted, remove the SIM card and SD card.
    • Remove midframe screws.
    • Carefully pry between the screen and midframe to release the clips holding it on.
    • Remove the midframe.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Carefully, with a pry pick, pry under the battery to cut the adhesive underneath it.
    • If you are having trouble, apply a heated iOpener onto the battery for another minute, then try again.
    • You can also apply a few drops of high concentration isopropyl alcohol to the edges of the battery to help soften the adhesive.
    • Remove the battery.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
Conclusão
Uma outra pessoa concluiu este guia.
Gigabit87898
Membro desde: 04/06/16
16.198 Reputação
Autoria de 3 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.523 guias
8 comentários
@gigabit87898 you should consider adding images for each step of any guide. A good guide points out where screws are located, what size they are and if they are all the same etc. It is not enough to write "Remove midframe screws". Remember, guides are written for anybody and keep in mind that people wanting to use your guide to fix their device, may not have your knowledge.
oldturkey03 - Responder
yeah i dont think im going to use a “heat gun” on my battery
Vinny Games - Responder
As long as you do it correctly, it will be fine.
Gigabit87898 -
I have a heat gun, but I think I’ll try a hair dryer first. In the comments under disassembly video at youtube one commenter said the adhesive is just double stick tape. Here’s the video: https://www.youtube.com/watch?v=LY5ltw1X...
Clint Murray - Responder
Why heat the battery?? I need to change the screen in my moms maven and I'm kinda scared tbh. Lol the protective cover freaks me out!! Help me plzzzz?!?
CaRrIe 4TwIn E - Responder
Heating the battery helps soften the adhesive holding the battery to the case. You definitely don’t need a heat gun. Try prying the battery out without using any heat first. It may just be harder to do, but it is a much safer alternative.
Arthur Shi -
This really makes no sense. I have a ZTE Maven 2 and literally all I would have to do to replace the battery is remove the back cover of the phone, take old battery out, put new battery in, replace back cover of the phone and it would be finished. Replacing the battery on a ZTE Maven 2 is nowhere NEAR as complicated as this article makes it.
AveMaria02 - Responder
Hi AveMaria02,
This guide is for a ZTE Maven 1 (Z812). It is a completely different phone from the Maven 2, as the original Maven has a glued-in battery.
Arthur Shi -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 3,768
