Ir para o conteúdo principal
ZTE Maven 3 Front Camera Replacement
O que você precisa
  1. ZTE Maven 3 Front Camera Replacement, Back Cover: passo 1, imagem 1 %32 ZTE Maven 3 Front Camera Replacement, Back Cover: passo 1, imagem 2 %32 ZTE Maven 3 Front Camera Replacement, Back Cover: passo 1, imagem 3 %32
    • Locate the small indent on the back right bottom corner of the phone.
    • Put the pry tool or your fingertip inside the small gap on the bottom right of the back of the phone and pop up the cover.
    • Continue to go around the phone until the cover is completely off the back of the pull and put it aside.
  2. ZTE Maven 3 Front Camera Replacement, Battery: passo 2, imagem 1 %32 ZTE Maven 3 Front Camera Replacement, Battery: passo 2, imagem 2 %32 ZTE Maven 3 Front Camera Replacement, Battery: passo 2, imagem 3 %32
    • Locate the battery in the middle of the back of the phone.
    • Push in and up on the battery to remove it from its slot.
    • Put the battery aside.
  3. ZTE Maven 3 Front Camera Replacement, Midframe: passo 3, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove twelve 2 mm screws along the back outer edges of the phone.
  4. ZTE Maven 3 Front Camera Replacement: passo 4, imagem 1 %32
    • There’s a 13th 2 mm screw with a lock sticker over it on the bottom right corner. Insert the #00 Phillips screwdriver in the middle, breaking the sticker, and take the screw out.
  5. ZTE Maven 3 Front Camera Replacement: passo 5, imagem 1 %32 ZTE Maven 3 Front Camera Replacement: passo 5, imagem 2 %32
    • Slide the pry tool into the middle of the connection between the screen and the back of the phone.
    • Once in, slide the pry tool around the phone, separating the screen and the back of the phone.
    • The detached piece is the midframe, and you can place it aside when detached.
  6. ZTE Maven 3 Front Camera Replacement, Front Camera: passo 6, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Detach the ribbon cable connecting the camera in the top middle left of the phone.
    • Use blunt tweezers to pull the camera off and put it aside.
Conclusão
Emma Thiboutot
Membro desde: 10/30/23
699 Reputação
Autoria de 8 guias
Equipe
UMass Dartmouth, Team 3-1, Konn Fall 2023 Membro de UMass Dartmouth, Team 3-1, Konn Fall 2023
UMASSD-KONN-F23S3G1
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 19
