Introdução
Replacing a battery becomes necessary when its capacity deteriorates over time, leading to diminished performance in devices. As batteries age, they hold less charge, resulting in shorter usage durations and frequent recharging.
Opting for a new battery ensures optimal functionality, prolonged usage, and reliable performance for your device.
O que você precisa
Locate the small indent on the back right bottom corner of the phone.
Put the pry tool or your fingertip inside the small gap on the bottom right of the back of the phone and pop up the cover.
Continue to go around the phone until the cover is completely off the back of the pull and put it aside.
Locate the battery in the middle of the back of the phone.
Push in and up on the battery to remove it from its slot.
Put the battery aside.
