Ir para o conteúdo principal
ZTE Maven 3 Back Camera Replacement
O que você precisa
  1. ZTE Maven 3 Back Camera Replacement, Back Cover: passo 1, imagem 1 %32 ZTE Maven 3 Back Camera Replacement, Back Cover: passo 1, imagem 2 %32 ZTE Maven 3 Back Camera Replacement, Back Cover: passo 1, imagem 3 %32
    • Locate the small indent on the back right bottom corner of the phone.
    • Put the pry tool or your fingertip inside the small gap on the bottom right of the back of the phone and pop up the cover.
    • Continue to go around the phone until the cover is completely off the back of the pull and put it aside.
    Pergunte ao FixBot
    Comentar
  2. ZTE Maven 3 Back Camera Replacement, Battery: passo 2, imagem 1 %32 ZTE Maven 3 Back Camera Replacement, Battery: passo 2, imagem 2 %32 ZTE Maven 3 Back Camera Replacement, Battery: passo 2, imagem 3 %32
    • Locate the battery in the middle of the back of the phone.
    • Push in and up on the battery to remove it from its slot.
    • Put the battery aside.
    Pergunte ao FixBot
    Comentar
  3. ZTE Maven 3 Back Camera Replacement, Midframe: passo 3, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove twelve 2 mm screws along the back outer edges of the phone.
    Pergunte ao FixBot
    Comentar
  4. ZTE Maven 3 Back Camera Replacement: passo 4, imagem 1 %32
    • There’s a 13th 2 mm screw with a lock sticker over it on the bottom right corner. Insert the #00 Phillips screwdriver in the middle, breaking the sticker, and take the screw out.
    Pergunte ao FixBot
    Comentar
  5. ZTE Maven 3 Back Camera Replacement: passo 5, imagem 1 %32 ZTE Maven 3 Back Camera Replacement: passo 5, imagem 2 %32
    • Slide the pry tool into the middle of the connection between the screen and the back of the phone.
    • Once in, slide the pry tool around the phone, separating the screen and the back of the phone.
    • The detached piece is the midframe, and you can place it aside when detached.
    Pergunte ao FixBot
    Comentar
  6. ZTE Maven 3 Back Camera Replacement, Back Camera: passo 6, imagem 1 %32 ZTE Maven 3 Back Camera Replacement, Back Camera: passo 6, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Detach the ribbon cable connecting the camera in the top middle of the phone.
    • Use blunt tweezers to pull the camera off and put it aside.
    • Using this same method, grab the tweezers and insert the replacement camera.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
UMass Dartmouth, Team 3-1, Konn Fall 2023 Membro de UMass Dartmouth, Team 3-1, Konn Fall 2023
UMASSD-KONN-F23S3G1
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 22
Ao todo: 268
