Introdução
This guide will show you how to access and remove the midframe of your ZTE Maven 2 (Model Z831). The midframe sits on top of the motherboard and screen and protects these components from damage. You may need to remove the motherboard to access these components.
O que você precisa
Pry off the back cover by inserting an opening tool into the small space on the bottom left between the phone's cover and body.
Work your way around the phone with an opening pick to loosen the rest of the back cover.
Remove the cover.
Push in and then up on the bottom of the battery to free it from its compartment.
Pull the battery out.
Ferramenta utilizada nesse passo:Tweezers$4.99
Using your fingers or blunt tweezers, carefully pull the memory card out of the slot.
Uma outra pessoa concluiu este guia.
