Ir para o conteúdo principal
ZTE Lever Volume Buttons Replacement
O que você precisa
  1. ZTE Lever Volume Buttons Replacement, Battery: passo 1, imagem 1 %32
    • Remove the SD card and the Sim card from the device.
    • The Sim and SD cards are not shown here as our device did not come with them.
  2. ZTE Lever Volume Buttons Replacement: passo 2, imagem 1 %32 ZTE Lever Volume Buttons Replacement: passo 2, imagem 2 %32
    • Use an iFixit opening tool to separate the back from the device.
  3. ZTE Lever Volume Buttons Replacement: passo 3, imagem 1 %32 ZTE Lever Volume Buttons Replacement: passo 3, imagem 2 %32
    • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
    • Remove the cover.
  4. ZTE Lever Volume Buttons Replacement: passo 4, imagem 1 %32 ZTE Lever Volume Buttons Replacement: passo 4, imagem 2 %32
    • Disconnect the battery cable from the motherboard with a plastic opening tool.
  5. ZTE Lever Volume Buttons Replacement: passo 5, imagem 1 %32
    • Use your hands, or a plastic opening tool, to pry the battery from the phone.
  6. ZTE Lever Volume Buttons Replacement, Volume Buttons: passo 6, imagem 1 %32
    • Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
  7. ZTE Lever Volume Buttons Replacement: passo 7, imagem 1 %32 ZTE Lever Volume Buttons Replacement: passo 7, imagem 2 %32 ZTE Lever Volume Buttons Replacement: passo 7, imagem 3 %32
    • Remove the top plastic motherboard cover using a plastic opening tool.
  8. ZTE Lever Volume Buttons Replacement: passo 8, imagem 1 %32 ZTE Lever Volume Buttons Replacement: passo 8, imagem 2 %32
    • Use a plastic opening tool to flip up the retaining flap on the volume ribbon cable ZIF socket.
  9. ZTE Lever Volume Buttons Replacement: passo 9, imagem 1 %32 ZTE Lever Volume Buttons Replacement: passo 9, imagem 2 %32
    • Peel up the volume button cable from the phone with hands, or plastic opening tool.
Conclusão
Michael Gonzalez
Membro desde: 01/29/18
501 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S5-G2, Passmore Spring 2018 Membro de USF Tampa, Team S5-G2, Passmore Spring 2018
USFT-PASSMORE-S18S5G2
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 97
