Ir para o conteúdo principal
ZTE Lever Screen Replacement
O que você precisa
  1. ZTE Lever Screen Replacement, Battery: passo 1, imagem 1 %32
    • Remove the SD card and the Sim card from the device.
    • The Sim and SD cards are not shown here as our device did not come with them.
  2. ZTE Lever Screen Replacement: passo 2, imagem 1 %32 ZTE Lever Screen Replacement: passo 2, imagem 2 %32
    • Use an iFixit opening tool to separate the back from the device.
  3. ZTE Lever Screen Replacement: passo 3, imagem 1 %32 ZTE Lever Screen Replacement: passo 3, imagem 2 %32
    • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
    • Remove the cover.
  4. ZTE Lever Screen Replacement: passo 4, imagem 1 %32 ZTE Lever Screen Replacement: passo 4, imagem 2 %32
    • Disconnect the battery cable from the motherboard with a plastic opening tool.
  5. ZTE Lever Screen Replacement: passo 5, imagem 1 %32
    • Use your hands, or a plastic opening tool, to pry the battery from the phone.
  6. ZTE Lever Screen Replacement, Volume Buttons: passo 6, imagem 1 %32
    • Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
  7. ZTE Lever Screen Replacement: passo 7, imagem 1 %32 ZTE Lever Screen Replacement: passo 7, imagem 2 %32 ZTE Lever Screen Replacement: passo 7, imagem 3 %32
    • Remove the top plastic motherboard cover using a plastic opening tool.
  8. ZTE Lever Screen Replacement: passo 8, imagem 1 %32 ZTE Lever Screen Replacement: passo 8, imagem 2 %32
    • Use a plastic opening tool to flip up the retaining flap on the volume ribbon cable ZIF socket.
  9. ZTE Lever Screen Replacement: passo 9, imagem 1 %32 ZTE Lever Screen Replacement: passo 9, imagem 2 %32
    • Peel up the volume button cable from the phone with hands, or plastic opening tool.
  10. ZTE Lever Screen Replacement, Power Button: passo 10, imagem 1 %32
    • Disconnect the power button from the motherboard with a plastic opening tool.
  11. ZTE Lever Screen Replacement: passo 11, imagem 1 %32 ZTE Lever Screen Replacement: passo 11, imagem 2 %32
    • Peel the power button cable up from the phone with you hands, or a plastic opening tool.
  12. ZTE Lever Screen Replacement, Motherboard: passo 12, imagem 1 %32 ZTE Lever Screen Replacement, Motherboard: passo 12, imagem 2 %32
    • Remove the seven 1.6mm Phillips #0 screws from the plastic cover on the bottom of the motherboard.
  13. ZTE Lever Screen Replacement: passo 13, imagem 1 %32
    • Remove the bottom plastic motherboard cover with your fingers
  14. ZTE Lever Screen Replacement: passo 14, imagem 1 %32 ZTE Lever Screen Replacement: passo 14, imagem 2 %32
    • Disconnect the camera from the motherboard with a plastic opening tool.
  15. ZTE Lever Screen Replacement: passo 15, imagem 1 %32
    • Disconnect the display cable from the motherboard with a plastic opening tool.
  16. ZTE Lever Screen Replacement: passo 16, imagem 1 %32 ZTE Lever Screen Replacement: passo 16, imagem 2 %32 ZTE Lever Screen Replacement: passo 16, imagem 3 %32
  17. ZTE Lever Screen Replacement: passo 17, imagem 1 %32
    • Disconnect the rear speaker cable from the motherboard with a plastic opening tool.
  18. ZTE Lever Screen Replacement: passo 18, imagem 1 %32
    • Pry the motherboard cell battery from its position on the case of the phone
  19. ZTE Lever Screen Replacement: passo 19, imagem 1 %32 ZTE Lever Screen Replacement: passo 19, imagem 2 %32 ZTE Lever Screen Replacement: passo 19, imagem 3 %32
    • Using the plastic opening tool, pry the motherboard up, sliding along the edge to separate the pieces.
  20. ZTE Lever Screen Replacement: passo 20, imagem 1 %32
    • Remove the motherboard with your fingers.
  21. ZTE Lever Screen Replacement, Screen: passo 21, imagem 1 %32 ZTE Lever Screen Replacement, Screen: passo 21, imagem 2 %32
    • Using the iFixit opening tool, pry off the screen from the case.
    • Be careful not to crack the case.
  22. ZTE Lever Screen Replacement: passo 22, imagem 1 %32 ZTE Lever Screen Replacement: passo 22, imagem 2 %32 ZTE Lever Screen Replacement: passo 22, imagem 3 %32
    • Slide the 2 ribbon cables through their respective holes before separating the case from the screen.
    • Gently lift up the case from the screen.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 251
