Introdução
This guide will show you how to replace the loud speaker on a ZTE Lever smartphone.
O que você precisa
Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
Disconnect the power button from the motherboard with a plastic opening tool.
Remove the seven 1.6mm Phillips #0 screws from the plastic cover on the bottom of the motherboard.
Quase terminado!
Conclusão
