Ir para o conteúdo principal
ZTE Jasper LTE Screen Replacement
O que você precisa
  1. ZTE Jasper LTE Screen Replacement, Battery: passo 1, imagem 1 %32
    • Insert the spudger into the bottom left corner of the phone.
    • Use the spudger to loosen the back cover.
  2. ZTE Jasper LTE Screen Replacement: passo 2, imagem 1 %32
    • Insert the black spudger near the bottom left of the battery. There will be an opening to easily to remove the battery.
    • Continuing to use tool, prop up the battery and remove it.
  3. ZTE Jasper LTE Screen Replacement, Camera: passo 3, imagem 1 %32 ZTE Jasper LTE Screen Replacement, Camera: passo 3, imagem 2 %32
    • Remove nine 0.8mm Phillips #00 screws.
  4. ZTE Jasper LTE Screen Replacement: passo 4, imagem 1 %32 ZTE Jasper LTE Screen Replacement: passo 4, imagem 2 %32
    • Remove the back cover by pulling upwards.
    • Removing the back cover may take a bit of force.
  5. ZTE Jasper LTE Screen Replacement: passo 5, imagem 1 %32 ZTE Jasper LTE Screen Replacement: passo 5, imagem 2 %32 ZTE Jasper LTE Screen Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Disconnect the gold component attached to the camera by pulling upwards using the tweezers.
    • Remove the camera using the tweezers by gripping tightly around the camera and pulling upwards.
    • Camera is attached to the motherboard with adhesive. As such, you may need to use light force to remove the camera.
  6. ZTE Jasper LTE Screen Replacement, Screen: passo 6, imagem 1 %32
    • Disconnect all of these parts from the motherboard.
  7. ZTE Jasper LTE Screen Replacement: passo 7, imagem 1 %32 ZTE Jasper LTE Screen Replacement: passo 7, imagem 2 %32 ZTE Jasper LTE Screen Replacement: passo 7, imagem 3 %32
    • Remove the 0.8mm Phillips #00 screw from the bottom right.
    • Disconnect the gold pin by pulling upwards with the tweezers.
  8. ZTE Jasper LTE Screen Replacement: passo 8, imagem 1 %32 ZTE Jasper LTE Screen Replacement: passo 8, imagem 2 %32 ZTE Jasper LTE Screen Replacement: passo 8, imagem 3 %32
    • Lightly disconnect the power button, volume button and the chip from the motherboard.
    • Be careful not to tear the volume and power button off the motherboard.
  9. ZTE Jasper LTE Screen Replacement: passo 9, imagem 1 %32 ZTE Jasper LTE Screen Replacement: passo 9, imagem 2 %32
    • Lightly move clip back to release the motherboard.
    • Gently pull the motherboard away from the screen.
Conclusão
Anthony Sou
Membro desde: 04/22/19
391 Reputação
Autoria de 4 guias
Equipe
UW Tacoma, Team S1-G1, Cardinal Spring 2019 Membro de UW Tacoma, Team S1-G1, Cardinal Spring 2019
UWT-CARDINAL-S19S1G1
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 32
Ao todo: 424
