Introdução
This guide contains the steps to remove the rear camera from the ZTE Grand X Max Plus.
If your camera is scratched or not working, you can follow these steps to replace it.
O que você precisa
Heat the phone using a heating pad, heat gun, or hair dryer to loosen the glue. You just need to heat the back of the phone.
Remove the screws from the upper part of the phone using a screwdriver with a JIS #000 head. There are (6) six screws that should be removed.
