Ir para o conteúdo principal
ZTE Grand X Max Plus Camera Replacement
O que você precisa
  1. ZTE Grand X Max Plus Camera Replacement, Back Cover: passo 1, imagem 1 %32
    • Make sure you turn off your phone before starting.
    • Heat the phone using a heating pad, heat gun, or hair dryer to loosen the glue. You just need to heat the back of the phone.
    • You can also use a hair dryer or a heating gun for this step.
    Pergunte ao FixBot
  2. ZTE Grand X Max Plus Camera Replacement: passo 2, imagem 1 %32 ZTE Grand X Max Plus Camera Replacement: passo 2, imagem 2 %32
    • After the phone is heated, use the blue plastic opening tool on both sides of the phone.
    • Don't apply too much pressure because the cover can crack easily.
    • To avoid that your cover cracks, you can add tape to back cover.
    • You can use a suction cup to help remove the battery.
    Pergunte ao FixBot
  3. ZTE Grand X Max Plus Camera Replacement: passo 3, imagem 1 %32 ZTE Grand X Max Plus Camera Replacement: passo 3, imagem 2 %32
    • Carefully remove the cover from the phone.
    Pergunte ao FixBot
  4. ZTE Grand X Max Plus Camera Replacement, Rear Camera: passo 4, imagem 1 %32 ZTE Grand X Max Plus Camera Replacement, Rear Camera: passo 4, imagem 2 %32
    • Remove the screws from the upper part of the phone using a screwdriver with a JIS #000 head. There are (6) six screws that should be removed.
    Pergunte ao FixBot
  5. ZTE Grand X Max Plus Camera Replacement: passo 5, imagem 1 %32 ZTE Grand X Max Plus Camera Replacement: passo 5, imagem 2 %32 ZTE Grand X Max Plus Camera Replacement: passo 5, imagem 3 %32
    • Use a plastic opening tool to remove the plastic piece that is protecting the motherboard.
    Pergunte ao FixBot
  6. ZTE Grand X Max Plus Camera Replacement: passo 6, imagem 1 %32
    • With a plastic opening tool, unclip the camera from the motherboard.
    Pergunte ao FixBot
  7. ZTE Grand X Max Plus Camera Replacement: passo 7, imagem 1 %32 ZTE Grand X Max Plus Camera Replacement: passo 7, imagem 2 %32 ZTE Grand X Max Plus Camera Replacement: passo 7, imagem 3 %32
    • After the camera is unclipped, remove it from the device.
    Pergunte ao FixBot
Conclusão
Jordano Baer
Membro desde: 10/02/17
716 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S9-G4, Remmell Fall 2017 Membro de USF Tampa, Team S9-G4, Remmell Fall 2017
USFT-REMMELL-F17S9G4
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 33
Ao todo: 355
