Ir para o conteúdo principal
ZTE Grand X Max Plus Battery Replacement
O que você precisa
  1. ZTE Grand X Max Plus Battery Replacement, Back Cover: passo 1, imagem 1 %32
    • Make sure you turn off your phone before starting.
    • Heat the phone using a heating pad, heat gun, or hair dryer to loosen the glue. You just need to heat the back of the phone.
    • You can also use a hair dryer or a heating gun for this step.
  2. ZTE Grand X Max Plus Battery Replacement: passo 2, imagem 1 %32 ZTE Grand X Max Plus Battery Replacement: passo 2, imagem 2 %32
    • After the phone is heated, use the blue plastic opening tool on both sides of the phone.
    • Don't apply too much pressure because the cover can crack easily.
    • To avoid that your cover cracks, you can add tape to back cover.
    • You can use a suction cup to help remove the battery.
  3. ZTE Grand X Max Plus Battery Replacement: passo 3, imagem 1 %32 ZTE Grand X Max Plus Battery Replacement: passo 3, imagem 2 %32
    • Carefully remove the cover from the phone.
  4. ZTE Grand X Max Plus Battery Replacement, Battery: passo 4, imagem 1 %32 ZTE Grand X Max Plus Battery Replacement, Battery: passo 4, imagem 2 %32
    • Use a plastic opening tool to pry the battery off.
    • The battery will be held down securely by glue, so it'll take quite a bit of sliding underneath to separate it from the compartment.
  5. ZTE Grand X Max Plus Battery Replacement: passo 5, imagem 1 %32 ZTE Grand X Max Plus Battery Replacement: passo 5, imagem 2 %32 ZTE Grand X Max Plus Battery Replacement: passo 5, imagem 3 %32
    • Pull up the piece that is connected to the motherboard. You can pull it using your nails.
  6. ZTE Grand X Max Plus Battery Replacement: passo 6, imagem 1 %32 ZTE Grand X Max Plus Battery Replacement: passo 6, imagem 2 %32
    • Remove the battery.
Conclusão
3 outras pessoas executaram este guia.
Jordano Baer
Membro desde: 10/02/17
689 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S9-G4, Remmell Fall 2017 Membro de USF Tampa, Team S9-G4, Remmell Fall 2017
USFT-REMMELL-F17S9G4
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 2,988
