Ir para o conteúdo principal
ZTE Compel Speaker Replacement
O que você precisa
  1. ZTE Compel Speaker Replacement, Battery: passo 1, imagem 1 %32
    • Place the phone on a flat surface with the screen facing down. This will allow easy access to the removable black plastic cover on the back of the phone.
  2. ZTE Compel Speaker Replacement: passo 2, imagem 1 %32
    • In the bottom right corner of the device, use your fingernail to remove the back cover of the phone by lifting up and holding the device with your other hand.
  3. ZTE Compel Speaker Replacement: passo 3, imagem 1 %32
    • In the top-right area of the battery, use your fingernail to lift the battery out of the phone.
    • If your battery is corroded, take all necessary precautions, such as, gloves and protective eyewear.
  4. ZTE Compel Speaker Replacement, Speaker: passo 4, imagem 1 %32 ZTE Compel Speaker Replacement, Speaker: passo 4, imagem 2 %32
    • Remove the 9 screws that measure 4 mm Phillips. Use your PH000 screwdriver attachment.
    • Use your iFixit Magnetic Project Mat to hold your removed screws while working on your ZTE Compel
  5. ZTE Compel Speaker Replacement: passo 5, imagem 1 %32 ZTE Compel Speaker Replacement: passo 5, imagem 2 %32 ZTE Compel Speaker Replacement: passo 5, imagem 3 %32
    • Insert the flat end of your black plastic spudger into the crease and work it around the entire circumference of the phone until the front and back are separated.
  6. ZTE Compel Speaker Replacement: passo 6, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • The speaker is located in the top-left corner of the back plate. Using your tweezers, grip the sides of the speaker and pull it out.
    • Be cautious pulling the speaker out as it might move while pulling it due to adhesive wearing away.
Conclusão
Tayler McCleese
Membro desde: 09/06/18
246 Reputação
Autoria de 2 guias
Equipe
Ohio State, Team S1-G4, Whitney Fall 2018 Membro de Ohio State, Team S1-G4, Whitney Fall 2018
OSU-WHITNEY-F18S1G4
Membros da 2
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 140
