Ir para o conteúdo principal
ZTE Blade Z Max Charging Port Card Replacement
O que você precisa
  1. ZTE Blade Z Max Charging Port Card Replacement, SIM Card: passo 1, imagem 1 %32 ZTE Blade Z Max Charging Port Card Replacement, SIM Card: passo 1, imagem 2 %32 ZTE Blade Z Max Charging Port Card Replacement, SIM Card: passo 1, imagem 3 %32
    • Turn the device on it side with the buttons away from you.
    • Using the SIM Card Eject Tool, insert the narrow end into the ejection hole.
    • Press firmly into the hole until the SIM card tray pops out far enough to grab with your fingers.
  2. ZTE Blade Z Max Charging Port Card Replacement: passo 2, imagem 1 %32 ZTE Blade Z Max Charging Port Card Replacement: passo 2, imagem 2 %32 ZTE Blade Z Max Charging Port Card Replacement: passo 2, imagem 3 %32
    • Pull the tray out with your fingers .
    • Remove the SIM card.
  3. ZTE Blade Z Max Charging Port Card Replacement, Fingerprint Sensor: passo 3, imagem 1 %32
    • Remove the one T2 screw from the side of the phone near where the SIM card tray was.
  4. ZTE Blade Z Max Charging Port Card Replacement: passo 4, imagem 1 %32 ZTE Blade Z Max Charging Port Card Replacement: passo 4, imagem 2 %32
    • Insert a plastic opening tool into the space where the SIM card tray used to be.
    • Gently pry the back away form the phone frame until you hear and audible click of the back separating.
  5. ZTE Blade Z Max Charging Port Card Replacement: passo 5, imagem 1 %32 ZTE Blade Z Max Charging Port Card Replacement: passo 5, imagem 2 %32
    • Insert the plastic opening tool into the space you created between the phone back and frame.
    • Slide the plastic opening tool along the outside of the phone, underneath the back, to separate the rest of the clips holding the back onto the frame.
  6. ZTE Blade Z Max Charging Port Card Replacement: passo 6, imagem 1 %32 ZTE Blade Z Max Charging Port Card Replacement: passo 6, imagem 2 %32
    • Rotate the back over to the side, being careful not to damage the fingerprint sensor ribbon cable.
    • Use a plastic opening tool to separate the fingerprint sensor from the back of the phone.
    • On reassembly, add a piece of simple scotch tape to hold the fingerprint sensor to the phone back.
    • Set the phone back aside.
  7. ZTE Blade Z Max Charging Port Card Replacement: passo 7, imagem 1 %32
    • Remove the 6 silver 2.9mm screws from the back of the phone with a JIS #000 bit.
    • Remove the 11 black 3.5mm screws with the same JIS #000 bit.
  8. ZTE Blade Z Max Charging Port Card Replacement: passo 8, imagem 1 %32 ZTE Blade Z Max Charging Port Card Replacement: passo 8, imagem 2 %32
    • Turn the phone over, with the screen up.
    • Insert the opening tool between the screen and the silver trim that surrounds it.
    • Run the plastic opening tool around the circumference of the phone to separate the clips of that hold the trim to the frame.
  9. ZTE Blade Z Max Charging Port Card Replacement: passo 9, imagem 1 %32 ZTE Blade Z Max Charging Port Card Replacement: passo 9, imagem 2 %32
    • Turn the phone back over, with the screen down.
    • Lift the trim piece off of the phone and set aside.
  10. ZTE Blade Z Max Charging Port Card Replacement: passo 10, imagem 1 %32 ZTE Blade Z Max Charging Port Card Replacement: passo 10, imagem 2 %32
    • Using a plastic opening tool, separate the fingerprint ribbon connector from the motherboard.
  11. ZTE Blade Z Max Charging Port Card Replacement, Charging Port Card: passo 11, imagem 1 %32 ZTE Blade Z Max Charging Port Card Replacement, Charging Port Card: passo 11, imagem 2 %32
    • Use a spudger to pry up the the antenna connector on the top right of the charging port card.
  12. ZTE Blade Z Max Charging Port Card Replacement: passo 12, imagem 1 %32
    • Use a plastic opening tool to pry up and remove the primary connector for the card, located on the top left of the card.
  13. ZTE Blade Z Max Charging Port Card Replacement: passo 13, imagem 1 %32 ZTE Blade Z Max Charging Port Card Replacement: passo 13, imagem 2 %32 ZTE Blade Z Max Charging Port Card Replacement: passo 13, imagem 3 %32
    • Use a plastic opening tool, spudger, or opening pick to separate the bottom edge of the card away from the phone.
    • Lift the bottom edge of the card high enough that you can grab it with your fingers, and simply remove it from the phone.
Conclusão
9 outras pessoas executaram este guia.
3 comentários
Thanks! $7 part on ebay & this guide saved me from having to buy a new phone!!!
Isabelle Cavender - Responder
Is there anything special about reassembly one should be aware of? I have read that side buttons are an issue. Tips for reassembly, or what to watch closely would be handy. Thanks!
pappybest - Responder
At the start of this procedure it stated to remove the battery. I never saw the battery being removed, or the power cable from the battery being disconnected from the board to isolate the power from the phone. Is this step necessary to replacing the charging port card. I know that the battery can be a bear removing it from the phone.
Timothy Snipes - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 2,923
