Ir para o conteúdo principal
ZTE Blade E Motherboard Replacement
O que você precisa
  1. ZTE Blade E Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • Using a spudger, remove the back panel of the phone.
  2. ZTE Blade E Motherboard Replacement: passo 2, imagem 1 %32 ZTE Blade E Motherboard Replacement: passo 2, imagem 2 %32
    • Remove the battery and SD card from the phone.
  3. ZTE Blade E Motherboard Replacement: passo 3, imagem 1 %32
    • Remove the five 4mm Philips #00 screws, circled in red, holding the the back down.
  4. ZTE Blade E Motherboard Replacement: passo 4, imagem 1 %32
    • Remove the back piece, exposing the motherboard.
  5. ZTE Blade E Motherboard Replacement: passo 5, imagem 1 %32 ZTE Blade E Motherboard Replacement: passo 5, imagem 2 %32 ZTE Blade E Motherboard Replacement: passo 5, imagem 3 %32
    • Flip up the three small tan clips holding the ribbons in place.
  6. ZTE Blade E Motherboard Replacement: passo 6, imagem 1 %32
    • Gently slide each of the three ribbons out of the motherboard.
  7. ZTE Blade E Motherboard Replacement: passo 7, imagem 1 %32
    • Slide the motherboard off of the ribbons detaching it from the front of the phone.
    Excelente gráfica,gran aporte
    Juan - Responder
    I have a ZTE Blade C370 in the workshop to change the LCD, I would like to be able to contribute some material. There is a tutorial where I can see what I need to be able to contribute. For example, the quality of the images and their descriptions.
    Alvaro Gomes - Responder
Conclusão
9 outras pessoas executaram este guia.
Lilia Johnson
Membro desde: 10/08/14
790 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 9-5, Leahy Fall 2014 Membro de USF Tampa, Team 9-5, Leahy Fall 2014
USFT-LEAHY-F14S9G5
Membros da 3
Autoria de 10 guias
Um comentário
Zte blade a506 insert sim card problem
Ali Jaffar - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 4,070
