Ir para o conteúdo principal
ZTE Blade E Battery Replacement
O que você precisa
  1. ZTE Blade E Battery Replacement, Removing the cover: passo 1, imagem 1 %32
    • Take a spudger and remove the back panel.
    Pergunte ao FixBot
    Comentar
  2. ZTE Blade E Battery Replacement, Removal: passo 2, imagem 1 %32
    • Carefully remove the battery with a spudger.
    Pergunte ao FixBot
    Comentar
  3. ZTE Blade E Battery Replacement, New battery: passo 3, imagem 1 %32
    • Take the new battery and place it into the slot. The phone should operate normally.
    Pergunte ao FixBot
    Comentar
Conclusão
8 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 9-5, Leahy Fall 2014 Membro de USF Tampa, Team 9-5, Leahy Fall 2014
USFT-LEAHY-F14S9G5
3 Membros
Autoria de 10 guias
2Comentários do guia
[http://Please help me fix my phone|I can’t tell what is wrong with my phone it won’t turn on I've had it on the charger for days!!!!!]
AHL DeRoche - Responder Compartilhar
where can I buy a replacement battery, model # Li3816T43P4h604550 For ZTE Blade
memeandmim - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 44
Ao todo: 10,621
