Ir para o conteúdo principal
ZTE Awe Headphone Jack Replacement
O que você precisa
  1. ZTE Awe Headphone Jack Replacement, Remove the back cover: passo 1, imagem 1 %32
    • Remove the back cover of the phone to expose the phone's mid-frame.
  2. ZTE Awe Headphone Jack Replacement, Remove battery: passo 2, imagem 1 %32
    • Pry the battery up and out of the phone.
  3. ZTE Awe Headphone Jack Replacement, Unscrew the phone's mid frame: passo 3, imagem 1 %32
    • Use the Phillips Head 00 screw driver to unscrew the seven 0.1mm screws from the phone's mid frame.
  4. ZTE Awe Headphone Jack Replacement, Separate the mid frame and the digitizer: passo 4, imagem 1 %32 ZTE Awe Headphone Jack Replacement, Separate the mid frame and the digitizer: passo 4, imagem 2 %32 ZTE Awe Headphone Jack Replacement, Separate the mid frame and the digitizer: passo 4, imagem 3 %32
    • Wedge the flat end of the spudger between the mid frame and the digitizer.
  5. ZTE Awe Headphone Jack Replacement, Expose the motherboard: passo 5, imagem 1 %32 ZTE Awe Headphone Jack Replacement, Expose the motherboard: passo 5, imagem 2 %32
    • Gently pry the mid frame away from the rest of the phone to expose the motherboard.
  6. ZTE Awe Headphone Jack Replacement, Remove the audio jack: passo 6, imagem 1 %32 ZTE Awe Headphone Jack Replacement, Remove the audio jack: passo 6, imagem 2 %32 ZTE Awe Headphone Jack Replacement, Remove the audio jack: passo 6, imagem 3 %32
    • Locate the audio jack at the upper right hand corner of the device.
    • Use the metal spudger to pry the motherboard away from the device.
    • Use the metal spudger to unfasten the audio jack and pull it away from the motherboard.
Conclusão
4 outras pessoas executaram este guia.
Jennifer DeMeo
Membro desde: 10/07/14
1.035 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-2, Leahy Fall 2014 Membro de USF Tampa, Team 1-2, Leahy Fall 2014
USFT-LEAHY-F14S1G2
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 2,516
