Introdução
Use this guide to help you replace your device's broken or cracked camera lens.
Once you successfully replace the camera lens, your device should now take higher quality pictures and videos.
O que você precisa
Remove the back cover using the notch at the bottom of the device.
Pull the back cover from the front panel gently to remove it.
Using your J00 screwdriver, unscrew each of the 8 Philips head screws from the black plate of the device.
Where you can see the front of the camera lightly push on the camera to remove the camera from its holding. The camera will come through the back.
Once out of the holding remove the clip holding it to the underside of the motherboard. Now the camera is removed.
Once the old camera is removed replace it with the new camera to complete the repair.
5 outras pessoas executaram este guia.
