Ir para o conteúdo principal
ZTE Avail 2 Camera Replacement
O que você precisa
  1. ZTE Avail 2 Camera Replacement, Battery: passo 1, imagem 1 %32 ZTE Avail 2 Camera Replacement, Battery: passo 1, imagem 2 %32 ZTE Avail 2 Camera Replacement, Battery: passo 1, imagem 3 %32
    • Before disassembling your ZTE Avail 2, be sure it is powered off.
    • Remove the back cover using the notch at the bottom of the device.
    • Pull the back cover from the front panel gently to remove it.
  2. ZTE Avail 2 Camera Replacement: passo 2, imagem 1 %32 ZTE Avail 2 Camera Replacement: passo 2, imagem 2 %32
    • Remove the battery by the notch in the back plate.
  3. ZTE Avail 2 Camera Replacement, Camera: passo 3, imagem 1 %32
    • Using your J00 screwdriver, unscrew each of the 8 Philips head screws from the black plate of the device.
  4. ZTE Avail 2 Camera Replacement: passo 4, imagem 1 %32 ZTE Avail 2 Camera Replacement: passo 4, imagem 2 %32
    • Using the spudger tool, pull up from underneath the back plate and pop off the piece.
  5. ZTE Avail 2 Camera Replacement: passo 5, imagem 1 %32 ZTE Avail 2 Camera Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using the tweezers remove the 4 orange ribbon cables. Do this by lifting their corresponding black connectors and pulling the ribbon out.
  6. ZTE Avail 2 Camera Replacement: passo 6, imagem 1 %32
    • On the left side you will see a cellular antenna cable wire. Remove this wire by gently pulling it off.
  7. ZTE Avail 2 Camera Replacement: passo 7, imagem 1 %32 ZTE Avail 2 Camera Replacement: passo 7, imagem 2 %32
    • Lift up the motherboard, this may require some force because it is held on by adhesive.
    • This will allow you to access the camera and the camera mount.
  8. ZTE Avail 2 Camera Replacement: passo 8, imagem 1 %32 ZTE Avail 2 Camera Replacement: passo 8, imagem 2 %32 ZTE Avail 2 Camera Replacement: passo 8, imagem 3 %32
    • Where you can see the front of the camera lightly push on the camera to remove the camera from its holding. The camera will come through the back.
    • Once out of the holding remove the clip holding it to the underside of the motherboard. Now the camera is removed.
    • Once the old camera is removed replace it with the new camera to complete the repair.
Conclusão
5 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 461
