Introdução
Use this guide to replace your perishing battery.
After successfully removing the battery, and putting a new battery in, your device should now power on properly.
Remove the back cover using the notch at the bottom of the device.
Pull the back cover from the front panel gently to remove it.
4 outras pessoas executaram este guia.
