Ir para o conteúdo principal
ZTE Avail 2 Battery Replacement
  1. ZTE Avail 2 Battery Replacement, Battery: passo 1, imagem 1 %32 ZTE Avail 2 Battery Replacement, Battery: passo 1, imagem 2 %32 ZTE Avail 2 Battery Replacement, Battery: passo 1, imagem 3 %32
    • Before disassembling your ZTE Avail 2, be sure it is powered off.
    • Remove the back cover using the notch at the bottom of the device.
    • Pull the back cover from the front panel gently to remove it.
  2. ZTE Avail 2 Battery Replacement: passo 2, imagem 1 %32 ZTE Avail 2 Battery Replacement: passo 2, imagem 2 %32
    • Remove the battery by the notch in the back plate.
    • Once you have removed the battery replace it with the new one.
    • Carefully insert the new battery with the connectors aligned correctly.
    • Gently push down on the battery until it clicks into place.
Conclusão
4 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 524
